popi Posted September 29, 2015 Report Share Posted September 29, 2015 HOPING SOMEONE CAN HELP HAVE A 2011 DODGE JOURNEY I THINK MY SUN ROOF IS LEAKING GONE TO YOU TUBE TO GET HELP THEY TALK ABOUT EVERYTHING EXCEPT ON WHAT MY PROBLEM IS. DOES ANYONE HAVE THE SAME PROBLEM THANKS IN ADVANCE FOR ALL REPLIES. dhh3 1 Link to comment Share on other sites More sharing options...
BrianS Posted September 29, 2015 Report Share Posted September 29, 2015 YOU SHOULD REALLY TURN OFF YOUR CAPS LOCK SO YOU STOP YELLING AT PEOPLE. A common leak problem with sunroofs is the drain tubes. They get plugged with leaves and other debris and are unable to drain off the water. Not sure on the DJ as I've not looked at mine, but I think they are at the front corners and run down the A-pillars. dhh3, jkeaton, rolly and 2 others 5 Link to comment Share on other sites More sharing options...
popi Posted September 30, 2015 Author Report Share Posted September 30, 2015 No harm was intended sir dhh3 1 Link to comment Share on other sites More sharing options...
rolly Posted September 30, 2015 Report Share Posted September 30, 2015 (edited) No harm was intended sir I think Brian was pulling your leg. Edited September 30, 2015 by rolly dhh3 and jkeaton 2 Link to comment Share on other sites More sharing options...
dhh3 Posted September 30, 2015 Report Share Posted September 30, 2015 (edited) There should be a set of rain drains that run down the C pillars, also. Do not use anything high pressure to clear the tubes: you run the risk of blowing the tubes off of the sun roof channel. Edited September 30, 2015 by dhh3 jkeaton 1 Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 1, 2015 Report Share Posted October 1, 2015 When does it leak, with a light rain, or high pressure situations like in the carwash? Could be a different cause depending on the situation... Please provide a tad more info. dhh3 and jkeaton 2 Link to comment Share on other sites More sharing options...
Scotty in NZ Posted September 21, 2017 Report Share Posted September 21, 2017 Looks like there are Front (A Pillar?) & Rear (C Pillar) drain hoses. 1) Remove Headliner... 2) Front Hoses - Disconnect the front hoses (2) from the sunroof assembly (1) - Release the support clips (3) and disconnect the lower grommet and remove the hose. 3) Remove Rear Hoses - Disconnect the rear hoses (2) from the sunroof assembly (1) and release the support clips (3). Link to comment Share on other sites More sharing options...
