How do you adjust headlight aim?
I tend not to have to drive my DJ at night too often, so it took a while to notice this. After a collision in March, my driver side headlight had to be replaced. Now the aim seems like it's off. The body shop SHOULD have set it, but that doesn't mean they did it exactly correct. Does anyone have the correct aiming points? Also, where are the adjustment screws located?
Turned out to be easier than I was hoping. The passenger light was still factory aimed, so it was a good reference point. When I parked it in my driveway, it lined up perfectly with a panel on the garage door. There is a 12mm bolt head on the back side of each headlight assembly. A 1/4" drive socket fits in perfectly.
Edited by bfurth
