Reverse Light Wires
The inside tail light modules are simple to take off. Open the gate, and you will see 2 plastic rivets. There are notches in the head. Use a small screwdriver to pull the rivet out. Then pull the whole plastic piece out. You can then pull the whole lamp module towards you - there are two pins that fit in rubber washers. Then, you can see the colors of all of the lights in the module. Fun, huh!
  • 7 months later...
I'm hooking up an aftermarket wireless back up camera system so I want to power the rear and front wireless modules from the reverse light power wires in front and rear. I found the reverse light power wire easily in the rear hatch by looking at the taillight (it's cream coloured on drivers side of my 2011 R/T) but I'm looking for somewhere in the front dash area to wire the wireless module that attaches to my reverse camera screen (Garmin GPS unit).
I currently have it powered by hooking into the fusebox under the glovebox, I used fuse that says RR Camera hoping that would be it but that fuse has constant power so leaves my GPS showing the B/U camera even Journey is not in reverse.
Looking for the wiring diagram or if anyone knows what wire I can tap into for the reverse lights up front - Or anyone know if there is a wire under the shifter bezel that has power when in reverse only?
Thanks for any help?
