Is this common?
Bubsy1106
I bought our 2012 back in april and we didn't notice this at 1st but now we are noticing a shudder in the down shift when the car is coming to s stop, I notice it right about 28 mph and then again around 18 mph. It every does it with increasing speed. just slowing to come to a stop? any ideas?
thanks
Edited by Bubsy1106
In my case I was noticing some shuddering and I had my brakes replaced.
Terry
Edited by Windancer
  • 4 weeks later...
Yes, we bought our's late March and about a month later it started doing that. The car has been at the dealership for repairs for this issue for 2 weeks now. After going back and forth with Chrysler they seem to think that it's the Valve Body in the Transmission that is causing this issue. They ordered a part, however it was hard to come by as the part is on Backorder. They called me this morning and said that they the part should be in tomorrow. I'm hoping that this will correct the issue. Sucks that on a brand new car they already have to crack open the transmission.
  • 2 weeks later...
My 2010 would bang and the unit would jump ahead when you stop, started at 3000km on a vac trip to the blackhills. I told them it was valve body. After a year of ignoring me the tech finally had it happen and he said he thought he was rear ended it was so violent. Turns out the trans was full of metal fillings and the valvebody would stick and when I stopped it built up alot of pressure then would shift into 1st delayed like you popped the clutch. So far im at 6500km on the 2012RT and its shifting fine. I sure hope yours is ok. It really takes alot out of the excitement of a new unit when its got a problem.
  • 1 year later...
