Hi! A 09' Dodge Journey Owner needing help!
Lin-Ken Taing-Lealao
So just today, as we were pulling out from the store, our Dodge Journey began to go haywire! The dashboard lights and indicators started flashing and beeping, my signal indicators wouldn't work but still signaled, the windshield wipers turned on without me turning it on, my gages would be normal then fall back as if it didn't work, then be normal, and fall back down, and then, my gas tank meter would all of a sudden fall to empty when my gas was originally half full.
Another thing is that my front windows would not roll back up but the back windows worked just fine. I can't lock or unlock my car from the inside so I can only use my key.
Can someone give me an idea of what is going on? I was able to drive with all this going on, but I was so afraid that thecar would shut off on me with my kids in it. Please help!
we had a minn-van all the gages started going crazy and the next day the van wouldnt start it was the battery going bad,replaced it and no more problems. hope that is all it is with your journey ,mopar batteries only last 2 or 3 yrs. max with all my cars. have the shop check your charging system also to make sure it is produceing enough current to charge the battery. good luck
Yes I would also suggest the battery is a likely culprit
as I had the exact same symptoms on my previous Dodge.
With all the computers in these vehicles anymore one
missed parameter on the CanBus circutry sets the TIPM
off into crazy mode.
  • 4 weeks later...
Thanks for the input! We tried starting the car and it went dead. Bought new battery in hopes everything would be fine. Put new battery in, car started fine but then... all the same things started occurring. What else can it be???
Had the exact same thing occur in our previous Journey (2009 SXT). The CAN C bus (Cabin Area Network module) has failed and is in default mode. Ours had 47K on it when this happened so we were out of warranty. Ended up trading it in for a 2010 SXT. Unless you're under warranty I'm not sure on the cost to fix as we ended up trading it. I think the service writer estimated $800-$1000, but I never really followed up on it.
My wife swore "Christine" invaded it.
