Hello friends, can you help me with how to open the high-pressure pipe in the refrigeration system?
muhd1999
Never attempt to open high-pressure AC refrigerant lines while the system is charged; high-pressure lines (often exceeding 200 to 300 psi) can cause severe frostbite or blind you. First, have a licensed technician evacuate the refrigerant using an automotive recovery machine. Once evacuated, disconnect the lines using a specialized spring-lock or disconnect tool.
