muhd1999 Posted July 13 Report Share Posted July 13 Hello friends, can you help me with how to open the high-pressure pipe in the refrigeration system? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 13 Report Share Posted July 13 55 minutes ago, muhd1999 said: Hello friends, can you help me with how to open the high-pressure pipe in the refrigeration system? Never attempt to open high-pressure AC refrigerant lines while the system is charged; high-pressure lines (often exceeding 200 to 300 psi) can cause severe frostbite or blind you. First, have a licensed technician evacuate the refrigerant using an automotive recovery machine. Once evacuated, disconnect the lines using a specialized spring-lock or disconnect tool. larryl 1 Quote Link to comment Share on other sites More sharing options...
