Hi. Has anyone ever removed their front wiper arms? If so, how did you do it? I’ve been trying to get mine off so I can realign my wiper arms since the driver side wiper keeps hitting the A pillar because of it being too high when in the park position.
I tried using a wiper arm puller and it wouldn’t fit because of the cowl panel, and then I made the stupid mistake of trying to force it to fit and then ended up cracking the plastic on the cowl panel.
Any suggestions?
I did two years ago. If never apart the taper fit needs lots of force to separate2026-06-2510_01.347311099780730300620.thumb.jpg.b42ea58d06b29e0770ab393ca4b28f79.jpg. I have a really old steering wheel puller that fit into the tight recess.
Removing without damaging is the hard part. Harbor Freight has some unusual pullers, that are cheap enough for one off use.
Cowling plastic would be cheap from auto recycler if you are replacing broken plastic.
  • 2 weeks later...
Good stuff, need to be creative sometimes. That works as long you don't damage threads on shaft. Although die could clean that problem up. Practicing on an auto wrecker vehicle can be a warm up for stuff you haven't done before. It often helps seeing things completely apart before starting some jobs.
