2late4u Posted April 4 Report Share Posted April 4 well a while ago one of my replacement led went out so I got to looking and found an extra one that I had from a different set and installed it on the drivers side.they both worked okay but since I seem to be flush with money,,,LOL,,I ordered a new set of eBay as Amazon doesn't carry the one I wanted...AUXITO 90006/hb4 it's the y13 style real compact and installs fairly easy...actually it is the same brand I first put in back many yrs ago then one burned out so I bought a different brand and then one of them finally burned out so onto the third set and hopefully the finally set cost around $44 off eBay and they don't flicker and they are nice and bright and they came positioned right after they are installed but they do give you instructions on how to rotate the position of the led lamps if necessary.................also when doing the drivers side which is real tight just remove the wire harness bracket that is attached with some Christmas tree plugs gives you a lot more more........ AUXITO Y13 Series 9006(HB4) LED Headlight Bulb Low Beam 6000K Conversion Kit Price: $40.84 Item ID: 394318593269 Order number: 07-14443-17315 Seller: omni-lamp SHENZHENSHI AXI KEJI YOUXIAN GONGSI Longgangqubantianjiedaowuheshequ Lipujie7haodezhonggongyeyuan5dong310shi Shenzhen, 518000 CN Fits your 2014 Dodge Journey Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 4 Report Share Posted April 4 Glad that you are satisfied with the way they work and longevity. Only "old red" has needed a low beam bulb replacement of all the DJ's, and that was a few years ago. I used to complain about the power of the low beams......until I had cataract surgery this last late summer. Standard bulbs seem FINE now to me! 2late4u 1 Quote Link to comment Share on other sites More sharing options...
