installed new led low beams
well a while ago one of my replacement led went out so I got to looking and found an extra one that I had from a different set and installed it on the drivers side.they both worked okay but since I seem to be flush with money,,,LOL,,I ordered a new set of eBay as Amazon doesn't carry the one I wanted...AUXITO 90006/hb4 it's the y13 style real compact and installs fairly easy...actually it is the same brand I first put in back many yrs ago then one burned out so I bought a different brand and then one of them finally burned out so onto the third set and hopefully the finally set cost around $44 off eBay and they don't flicker and they are nice and bright and they came positioned right after they are installed but they do give you instructions on how to rotate the position of the led lamps if necessary.................also when doing the drivers side which is real tight just remove the wire harness bracket that is attached with some Christmas tree plugs gives you a lot more more........
mail?url=https%3A%2F%2Fsvcs.ebay.com%2Fi
Price:
$40.84
Item ID:
394318593269
Order number:
07-14443-17315
Seller:
omni-lamp
SHENZHENSHI AXI KEJI YOUXIAN GONGSI
Longgangqubantianjiedaowuheshequ
Lipujie7haodezhonggongyeyuan5dong310shi
Shenzhen, 518000
CN
Fitment BadgeFits your 2014 Dodge Journey
Glad that you are satisfied with the way they work and longevity.
 Only "old red" has needed a low beam bulb replacement of all the DJ's, and that was a few years ago. I used to complain about the power of the low beams......until I had cataract surgery this last late summer. Standard bulbs seem FINE now to me!
