Rgant_1981 Posted February 24 Report Share Posted February 24 I’ve added a video describing what’s going on. 2010 dodge journey with instrument cluster not working, windshield wipers on constantly (took the fuse out so they won’t run), steering wheel controls don’t work (multifunction switch don’t work. I’ve disconnected the battery and left it powerless for more than 8 hrs, still no luck. When I decides to drive it 3 days later, everything works again like nothing happens. Then it acts up again after a day and a half. It cranks fine and runs good. Checked fuses all good. Anyone else had/has this issue? 79366385142__9C596DA2-1815-4CEB-876D-103295180FF6.MOV Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 25 Report Share Posted February 25 Any codes stored ? 2009-10 were the years with tipm issues. Can do a lot of weird things, random horn honking, lights staying on issues etc. People have made up their own bypass harness to trouble shoot if it is the actual problem. Can reseat module, clean up connection contacts with rubbing alcohol or electronic cleaner. Bad solder joint often is the real cause, reman units are available. Free advice worth everything you pay for it. 🙂 2late4u 1 Quote Link to comment Share on other sites More sharing options...
