BlueRam Posted December 23, 2025 Report Share Posted December 23, 2025 Hi everyone, I have a Dodge Journey 2012 facelift (SXT), 3.6L, FWD. From the factory, the vehicle was not equipped with heated seats and a heated steering wheel. I sourced the seats and steering wheel from a salvage yard, but it turns out that’s not enough. The connector where the seat plugs in goes down into the floor, and in my car those connectors have significantly fewer wires. I was able to trace the additional wires up to the firewall; they go behind the HVAC unit, but I couldn’t trace them any further. Does anyone have photos, wiring diagrams, or schematics showing this wiring—specifically where these additional wires go and how they are routed? I would be extremely grateful for any help, as winter has arrived and I’d really prefer not to freeze in the car every morning 🙂 Thank you in advance! Photo shows connector with extra wiring Quote Link to comment Share on other sites More sharing options...
larryl Posted December 23, 2025 Report Share Posted December 23, 2025 You will need more than wiring there's modules and the BCM would need to be set up Also the Uconnect might need to be upgraded as it involves the touch screen...good luck Quote Link to comment Share on other sites More sharing options...
BlueRam Posted December 23, 2025 Author Report Share Posted December 23, 2025 1 hour ago, larryl said: You will need more than wiring there's modules and the BCM would need to be set up Also the Uconnect might need to be upgraded as it involves the touch screen...good luck Thanks for answer. I already have updated uconnect and I guess I have all modules I need. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 24, 2025 Report Share Posted December 24, 2025 Clock spring in steering column for air bags\horn are different in heated steering wheel optioned cars. Keep it in mind if heated steering doesn't work when enabled by alpha obd programmer. May have to add a wire or get heated steering wheel vehicle clock spring to install from wrecker. Our 2014 journey has the heated steering wheel, only turns on in the 8.4" main screen. Very nice in the winter. larryl 1 Quote Link to comment Share on other sites More sharing options...
Dean H Posted December 25, 2025 Report Share Posted December 25, 2025 Do you have the heated seats module, secured to the underside of the drivers seat? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 26, 2025 Report Share Posted December 26, 2025 He hasn't mentioned driver powered seat function. Probably a mouth full of turkey right now. If it's power to power seat swap, that harness may already have the heated seat wires in it. Would make it simpler. Active head restraints are on some US models, but I believe not north of border models. One less thing to worry about I guess. Quote Link to comment Share on other sites More sharing options...
BlueRam Posted December 26, 2025 Author Report Share Posted December 26, 2025 Of course the seat has that module. The question is not about the module or anything else. I’m asking specifically about the wiring that goes from the connector in the floor under the carpet. On 12/24/2025 at 6:16 PM, Dean H said: Do you have the heated seats module, secured to the underside of the drivers seat? Quote Link to comment Share on other sites More sharing options...
BlueRam Posted December 26, 2025 Author Report Share Posted December 26, 2025 On 12/23/2025 at 11:07 PM, John/Horace said: Clock spring in steering column for air bags\horn are different in heated steering wheel optioned cars. Keep it in mind if heated steering doesn't work when enabled by alpha obd programmer. May have to add a wire or get heated steering wheel vehicle clock spring to install from wrecker. Our 2014 journey has the heated steering wheel, only turns on in the 8.4" main screen. Very nice in the winter. Thank you for answer. Quote Link to comment Share on other sites More sharing options...
BlueRam Posted December 26, 2025 Author Report Share Posted December 26, 2025 6 hours ago, John/Horace said: He hasn't mentioned driver powered seat function. Probably a mouth full of turkey right now. If it's power to power seat swap, that harness may already have the heated seat wires in it. Would make it simpler. Active head restraints are on some US models, but I believe not north of border models. One less thing to worry about I guess. Thanks. If I had the required wires, I wouldn’t have created this thread. The wires are not there — that’s exactly why this topic exists. And my question is not about headrests, not about the module, and not about power seats. The presence of a power seat does not 100% mean the presence of heated seats. Quote Link to comment Share on other sites More sharing options...
BlueRam Posted December 26, 2025 Author Report Share Posted December 26, 2025 Thanks everybody for the “help”. I’ve already found all the wiring diagrams in the service manual, which was kindly posted in another forum thread. Quote Link to comment Share on other sites More sharing options...
larryl Posted December 27, 2025 Report Share Posted December 27, 2025 Wire them up.... Dean H 1 Quote Link to comment Share on other sites More sharing options...
