Debi M Posted September 21, 2025 Report Share Posted September 21, 2025 (edited) I have a 2009 Dodge Journey 6 cyl sxt. I was getting no heat on the passenger side. Checked blend door actuator and that was working fine. Replaced heater core, then no air was coming out of any of the vents. Blower motor is working, tried replacing the resistor, still no air from vents. I have no idea what to do next. Any help would be sincerely appreciated. power at plugs, blower works when jumped. relay is inside of control unit, tested with scan tool, registers fan up and down buttons being pressed. Just answer guy said its a wiring issue. hoping for other answers as sometimes cars do odd things. Edited September 21, 2025 by Debi M Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 22, 2025 Report Share Posted September 22, 2025 are you saying you have power to the res plug? here is a youtube video showing the res location and replacement, some of the comments are saying they don't have a res in that location,,,that said if you don't have one there than you probably need to take it to a garage that has the knowledge and tools to figure out what is wrong and what to replace it...also dealership parts counter should have some info on where the res is located as well//good luck.................. larryl 1 Quote Link to comment Share on other sites More sharing options...
Debi M Posted September 25, 2025 Author Report Share Posted September 25, 2025 It was the HVAC control module plug. I didn't have it properly seated. Thank you for your reply though 2late4u 1 Quote Link to comment Share on other sites More sharing options...
