2013journey Posted July 31, 2025 Report Share Posted July 31, 2025 engine chugs randomly - sometimes CEL comes on - but no codes - why ? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted July 31, 2025 Report Share Posted July 31, 2025 33 minutes ago, 2013journey said: engine chugs randomly - sometimes CEL comes on - but no codes - why ? When does it randomly "chug"? while driving , coming to a stop, or idling? How are you retrieving codes {or attempting to retrieve}? A scanner plugged into the OBD lnk under the dash is needed to get codes. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2013journey Posted August 1, 2025 Author Report Share Posted August 1, 2025 chugs while driving - low speed ... 25-30 mph OBD was scanned at Oreilly's. It has 102,000 miles on it. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 1, 2025 Report Share Posted August 1, 2025 5 hours ago, 2013journey said: chugs while driving - low speed ... 25-30 mph OBD was scanned at Oreilly's. It has 102,000 miles on it. At 102k miles....what normal engine /trans. services have been done? Sparkplugs Trans oil AND filter change I'm not sure how high a a level scanner system that parts store uses, may need to have it scanned by "shop" {higher level} scanner that can retrieve more than basic codes. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted August 1, 2025 Report Share Posted August 1, 2025 Even coil packs might need to be changed they do wear out Quote Link to comment Share on other sites More sharing options...
2013journey Posted August 2, 2025 Author Report Share Posted August 2, 2025 At 102k miles....what normal engine /trans. services have been done? Sparkplugs Trans oil AND filter change NONE of the above ... yet. Wouldn't spark plugs mis fire more often & all speeds ? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted August 2, 2025 Report Share Posted August 2, 2025 6 hours ago, 2013journey said: At 102k miles....what normal engine /trans. services have been done? Sparkplugs Trans oil AND filter change NONE of the above ... yet. Wouldn't spark plugs mis fire more often & all speeds ? The two things I asked are the most commonly neglected maint. items that are known common causes of the symptom you describe having and the best place to start. Unfortunately, on a forum responders don't see the state of the vehicle or conditions under which "quirks" are happening to give specific "here's what you need to replace/fix" answers to what little information a poster has given. Particularly when stated SOMETIMES CEL comes on but no codes, with a good scanner that can retrieve code history,more help is made available to fixing a situation. When the CEL is activated, the car's computer WILL log it in it's memory. I suggest you start with these 3 things I posted of and go from there. Keep in touch with us here for more "advice" from the membership here once your NORMAL maint. is up to date. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2013journey Posted September 12, 2025 Author Report Share Posted September 12, 2025 Actually, it happens at a stop or stop light. Could this be a transmission issue - TCC / solenoid. It has the 12 bolt pan - 6 speed. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted September 12, 2025 Report Share Posted September 12, 2025 6 hours ago, 2013journey said: Actually, it happens at a stop or stop light. Could this be a transmission issue - TCC / solenoid. It has the 12 bolt pan - 6 speed. With the complications of todays highly computerized cars, as much specific info of a concern needs to be posted to get good suggestions of possible fixes. Your vehicle is at the point of normal servicing that has been suggested to get done FIRST Next step would be a full system scan, a BASIC OBD11 scanner will not get to certain codes(autozone, O'Rielleys, etc}, as you say sometimes CEL but no codes YES there MAY be something going on with the TCC solenoid, but my experience {having 3 3.6 AWD's} is that this is not a highly likely cause. This is more likely to show up with the 4 cyl. 4 speed trans. Dean H and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
