pba1817 Posted March 15, 2025 Report Share Posted March 15, 2025 2012 Dodge Journey 3.6L SXT Anyone diagnose this noise? It is heard at low end throttle with rpm between 800-1200, also repeatable when engaging power steering(turning steering wheel), as well as when the A/C is turned on(this is what is heard in the video). https://streamable.com/j3ygdv Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 15, 2025 Report Share Posted March 15, 2025 9 minutes ago, pba1817 said: 2012 Dodge Journey 3.6L SXT Anyone diagnose this noise? It is heard at low end throttle with rpm between 800-1200, also repeatable when engaging power steering(turning steering wheel), as well as when the A/C is turned on(this is what is heard in the video). https://streamable.com/j3ygdv NOPE. Can't DIAGNOSE it, but can give an educated GUESS for you....... From the noise change on A/C engagement, I'd be looking into the A/C compressor clutch pulley or the compressor itself. Good Luck and keep us posted. pba1817 and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
pba1817 Posted March 15, 2025 Author Report Share Posted March 15, 2025 This is also heard when AC is not on. Heard alone; with low throttle engagement, or when turning steering wheel with no throttle, or when turning on A/C with no throttle. Quote Link to comment Share on other sites More sharing options...
Dean H Posted March 16, 2025 Report Share Posted March 16, 2025 (edited) I would check everything that is run by the serpentine belt. Check all your engine fluid levels. Need a second opinion on this thought: Could you run the engine for a few minutes without the serpentine belt on it? To see if you hear the noise then. Only when the engine is cold, you do not want to overheat the engine. Edited March 16, 2025 by Dean H pba1817 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 16, 2025 Report Share Posted March 16, 2025 Yes, good points to check posted by member Dean H. BUT if all that checks out OK, you will want to move further acroos the motor and check for a cracked/breaking flex plate{flywheel}. I had this happen on my '14 and a few others here have posted of same situation. Depending on how bad the crack is determines just how bad the noise it will make is. NOT an easy item to diagnose from sound alone and requires a good "visual" inspection from underneath the car here the trans. bolts up to the engine. pba1817 1 Quote Link to comment Share on other sites More sharing options...
pba1817 Posted March 16, 2025 Author Report Share Posted March 16, 2025 Thanks guys, pulling it apart on Tuesday and will report back Quote Link to comment Share on other sites More sharing options...
pba1817 Posted March 19, 2025 Author Report Share Posted March 19, 2025 Replaced idle pulley, replaced tensioner assembly, replaced serpentine belt. Noise still exists, most noticeable when turning on AC. AC blows cold, so maybe AC clutch? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 19, 2025 Report Share Posted March 19, 2025 OK, due to the year of vehicle, you probably did NOT "waste" money replacing those parts. BUT I would get the front end up in the air and go underneath and check for a cracked flex plate/ flywheel. This is a visual inspection with engine off and rotating the crankshaft with socket and ratchet from the pulley bolt on the pass. end. There may be a small inspection plate to remove from the trans. bell housing to see the flex plate and also should be numerous youtube videos about the flex plate to give you some guidance about the situation. ALL auto trans 3.6 Dodge/ Chryslers would be the same design and procedures{ DJ. Caravan, Town&Country. As I said before, locating by sound to particular area is rather difficult for pinpointing the source IF the flexplate is cracked. and you say that the A/C seems to work fine. NO MORE parts chucking, do a good visual inspection. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 19, 2025 Report Share Posted March 19, 2025 The next step, and I did not post before due to parts and MUCH LABOR would be to check for bad rocker arm/wiped out camshaft lobe. This is labor intensive, as upper manifold and valve covers need to be removed and visually inspected.Again, there are many youtube videos to help you along about the subject. A/C compressor or clt0utch is EXPENSIVE, so do your best to LOCATE the source of noise BEFORE spending more $$$ changing parts. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Dean H Posted March 19, 2025 Report Share Posted March 19, 2025 (edited) If you haven't run the engine with out the serpentine belt on the engine. Since your repairs. I would run the engine until the noise is occuring. With the belt on. Remove the belt and run it a few minutes. Under the same load. To eliminate any possibility of the AC clutch or water pump pulley. Being your problem. Edited March 19, 2025 by Dean H Quote Link to comment Share on other sites More sharing options...
pba1817 Posted March 19, 2025 Author Report Share Posted March 19, 2025 (edited) I pulled serpentine belt off, started engine ran it briefly and the noise is still heard without any serpentine components engaged. I assume that points to flex plate as you have previously indicated? I am getting beyond my level of comfort in the repairs so I am taking it to my mechanic on Monday. 9 hours ago, 5rebel9 said: OK, due to the year of vehicle, you probably did NOT "waste" money replacing those parts. BUT I would get the front end up in the air and go underneath and check for a cracked flex plate/ flywheel. This is a visual inspection with engine off and rotating the crankshaft with socket and ratchet from the pulley bolt on the pass. end. There may be a small inspection plate to remove from the trans. bell housing to see the flex plate and also should be numerous youtube videos about the flex plate to give you some guidance about the situation. ALL auto trans 3.6 Dodge/ Chryslers would be the same design and procedures{ DJ. Caravan, Town&Country. As I said before, locating by sound to particular area is rather difficult for pinpointing the source IF the flexplate is cracked. and you say that the A/C seems to work fine. NO MORE parts chucking, do a good visual inspection. Edited March 19, 2025 by pba1817 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 19, 2025 Report Share Posted March 19, 2025 YES, NOW is the time to do the VISUAL INSPECTION for a cracked flexplate. It is the LEAST COSTLY thing to pinpoint the source of noise to be able to EFFECTIVELY fix the noise problem as I posted of. pba1817 1 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted March 19, 2025 Report Share Posted March 19, 2025 20 minutes ago, pba1817 said: I pulled serpentine belt off, started engine ran it briefly and the noise is still heard without any serpentine components engaged. I assume that points to flex plate as you have previously indicated? I am getting beyond my level of comfort in the repairs so I am taking it to my mechanic on Monday. YES, if not sure of your abilities that is the right thing to do. It would be a good move to offer the info of checking the flex plate first and then broach the possibility of bad rocker arm/camshaft. IF either of those are the culprit, be prepared for a rather costly {@ $1500.}repair GOOD LUCK and PLEASE keep us informed. pba1817 1 Quote Link to comment Share on other sites More sharing options...
pba1817 Posted March 19, 2025 Author Report Share Posted March 19, 2025 16 minutes ago, 5rebel9 said: YES, NOW is the time to do the VISUAL INSPECTION for a cracked flexplate. It is the LEAST COSTLY thing to pinpoint the source of noise to be able to EFFECTIVELY fix the noise problem as I posted of. thank you for the help. Quote Link to comment Share on other sites More sharing options...
pba1817 Posted May 9, 2025 Author Report Share Posted May 9, 2025 Flex plate done, noise is gone. Now getting p0420 and occasional p0430 codes. Seems coincidental to get these codes immediately following this flex plate replacement. Throttle body is new. I also was getting this p0420 code about 5 years ago and it was associated with TSB 10-008-13, I had the dealership do this recall/TSB work and this code stopped. The purpose of TSB SB-10058834-5427 was to address instances where certain Chrysler/Dodge/Jeep vehicles with the 3.6L Pentastar were incorrectly setting Diagnostic Trouble Code (DTC) P0420 - Catalyst System Efficiency Below Threshold Bank 1. The goal of the TSB was to fix a problem where the vehicle's computer (PCM) was mistakenly thinking the Bank 1 catalytic converter was not working efficiently, even when it might have been. Here's a breakdown of the key purposes: Prevent False P0420 Codes: The primary aim was to reduce the occurrence of unnecessary Check Engine Lights and P0420 DTCs, which could lead to unwarranted repairs and customer dissatisfaction. Improve Catalyst Monitoring Accuracy: The updated PCM software calibration aimed to provide a more accurate assessment of the catalytic converter's performance under various driving conditions, reducing the likelihood of false positives. Provide a Standardized Repair Procedure: The TSB offered dealerships a specific and approved method (PCM reprogramming) to address this known issue. It ensured consistent repairs across different service centers. Address Potential Customer Concerns: By resolving the false P0420 codes, the TSB aimed to alleviate customer concerns about potential emissions system malfunctions and the need for catalytic converter replacements. Guide Dealers on When to Replace the Catalyst: The TSB also clarified that if the PCM reprogramming didn't resolve the P0420 code, then a genuine catalytic converter issue might be present, and replacement would be the necessary next step. In essence, the TSB was a service action to refine the software logic that monitors the catalytic converter to avoid misdiagnosing its efficiency. It was about improving the accuracy of the onboard diagnostics related to the P0420 code. My question- is it possible that disconnecting the battery for a long period to do the flex plate replacement reverted the ecm back to factory settings and began triggering the code again? Quote Link to comment Share on other sites More sharing options...
