do you have 2 remotes? might try replacing the batteries? or remove the batteries and then reinstall them kind of like rebooting your computer but sounds like maybe the button on the remote is staying engaged, have never heard of this problem...good luck and please report back on your solution in case others has this happen to them
This could be a short in the system somewhere or an issue with the FOB itself. If the FOB got wet, it might be sending a signal without you pushing the button. If there is a short on one of the actuators, it might be causing the remote module unit to think it needs to lock the doors (hence unlock then lock). If the remote module is going bad, this might be your sign. The last thing to check (or the first one) would be the fuse to the remote module. It's cheap, might just try to replace it. We had a similar issue on another car, turned out to be a bad module.
