Brake fluid moisture tester
None I’m sure. I think around 5 yrs is about right. Starts to get really dark after approx 7-8 yrs. Instead of pushing dirty fluid back through abs system  you can bleed it out at the caliper, then top up reservoir. Swaps a bit of the fluid.
