2014 Journey- haul wheelchair
I am looking to get a tow package on my 2014 Journey- 4cyl.   The carrier is about 75lbs and the chair is about 300lbs.  If I buy the Dodge package it's rated for plenty of weight but the more research I do the more nervous I get about the car being able to handle the tongue weight.  Any advice,  this is going to be my first time hauling anything...
i have a 2014 3.6  and we haul my wife's 3 wheel med scooter on a carrier (75lbs) and  her scooter weighs about 175 lbs..journeys seams to handle it great. i have had some problems with the upper rear toe links that were OEM that got out of adj and ruined a set of tires so i had some adj toe links (aftermarket) installed so i can keep the 4 wheel alignment correct....but if you chair weighs 300 lbs i believe you will have a lot of problems...good luck
