Interior dome (map) lights.
My interior dome (map) lights flicker when rear hatch is open.
They go from bright to dim pretty rapidly.
If the driver door is open they don't do it.
Also, it just started this:
Whenever I shift into reverse, the dome (map) lights come on bright.
Once I shift into drive, they stay on but are dim.
It doesn't matter which setting the switch is in either.
Does anyone know what the issue could be?
Thanks in advance.
