NiceTrip Posted January 21, 2017 Report Share Posted January 21, 2017 On my 2009 Journey, I have a longstanding issue causing the left front brake to drag. At first I didn't notice it while driving, I just had uneven brake wear. The first time I saw this, I checked the obvious things like caliper pins, and didn't find a cause, so I replaced the caliper and flex hose, and figured it was fixed. A few thousand miles later, the left front pads were worn out again. This time I replaced the ABS hydraulic control module. Now it's bad enough that 10 miles at highway speed heats things up enough that I get a vibration when I brake, and when I stop the left front wheel is noticeably hotter than the right. So I went ahead and did the 2014 front brake upgrade, replacing both front calipers, rotors, and pads with the upgraded dual cylinder calipers and 330 mm rotors. Still the left front gets hot at highway speeds. I don't see any kinks in the hard brake line, though I haven't replaced that yet. I'm pretty sure this is a pressure retention issue, because if I jack up the car and spin the wheel I can feel resistance, but if I crack open the line or bleeder, it releases. Also I would expect replacing the caliper and mounting bracket would fix any mechanical sticking. Could this be a master cylinder problem? Does the journey use a front/rear split for primary/secondary, or is it diagonal? I'll try and check the rear for uneven wear to check for this problem, but what else can I check. I'm tired of throwing money at this problem, and don't feel safe driving the car for long distances as it is. Quote Link to comment Share on other sites More sharing options...
dominic58 Posted January 21, 2017 Report Share Posted January 21, 2017 i had the same problem the caliper would get very hot after driving on the freeway in rush hour traffic, replacing it and ceramic pads seem to fix it, however i did learn that there is a different rotor for cars with adjustable pedals, why i dont know? maybe that is part of the problem. Quote Link to comment Share on other sites More sharing options...
Dusty256 Posted January 23, 2017 Report Share Posted January 23, 2017 (edited) you might want to check the BAS system .. it's the stability control. my 2009 did that a year and a half ago . after replacing the front brake the left side still got warm. i ended up disconnection the battery for ten minutes and then pushing the brake pedal to drain any remaining stored battery voltage. after replacing the battery start the car and before moving turn the stearing lock to lock returning to center. make sure the car is on a level surface. Edited January 23, 2017 by Dusty256 Blazer454, johanbrandon and Checkitgroovy 1 2 Quote Link to comment Share on other sites More sharing options...
Checkitgroovy Posted October 7, 2018 Report Share Posted October 7, 2018 Thanks man. Worked like a charm. Quote Link to comment Share on other sites More sharing options...
Blazer454 Posted January 29, 2024 Report Share Posted January 29, 2024 (edited) On 1/22/2017 at 9:33 PM, Dusty256 said: you might want to check the BAS system .. it's the stability control. my 2009 did that a year and a half ago . after replacing the front brake the left side still got warm. i ended up disconnection the battery for ten minutes and then pushing the brake pedal to drain any remaining stored battery voltage. after replacing the battery start the car and before moving turn the stearing lock to lock returning to center. make sure the car is on a level surface. This actually worked!! Thanks @Dusty256. Had brake troubles for about 6 months! Replaced everything. Same issue, front brakes were dragging bad, especially driver’s side. Over heating. Found this post and was skeptical. @Dusty256 proved me wrong. Took a couple days to fully free up but it immediately improved after doing the reset. by the way, the Negative extension on the shock tower under the hood disconnects power. (Don’t have to get to the battery to disconnect). Hope this helps. @Dusty256, I have a cold ? ready for you when ever you would like to collect!!? Edited January 29, 2024 by Blazer454 Add position 2late4u 1 Quote Link to comment Share on other sites More sharing options...
