U Connect TouchScreen Not Responding
Good evening,
i was was wondering if someone can help me my UConnect today for some reason isn't responding at all.
I can hit the power button and it works the radio comes on every other function works but I can't touch the screen because it doesn't respond like it's frozen.
Ive shut off the ride turned it back on same thing.
Any idea what it could be?
Thanks guys
Likely the digitiser is dead/locked up/unplugged.  You can try disconnecting the battery for a few minutes and reconnecting it to see if that helps, but if not you might consider opening the dash and checking to ensure all plugs are in tightly.  If that doesn't solve it and assuming you don't have an extended warranty then your best bet is likely to be eBay or a scrap yard..
No.  I have had occasional hiccups, like the half day and 10 starts where the screen was blanked out altogether - no display at all, but the touch part worked ad the radio played and the Bluetooth was functional - and it wasn't just the backlight.  But it came back towards the end of the day and hasn't happened again . . . .
The reality is that a car today is a networked array of computers powered by a rather poor power source and mediocre code and comprised of components built by the lowest cost bidder.  That's a tough environment in which to chase long term reliability, which is why I always counsel people to get extended warranties from the manufacturer.
