Stock backup cam and add-on monitor solution suggestions please
I want (need) a backup cam on my '14 DJ. I would probably install the OEM cam where the liftgate license plate light panel is. I will not be altering my 4.3 radio in any way and want to add on a monitor.
I am looking for suggestions on brand (if you already installed one) and mounting location for the monitor. I would probably look for something on amazon or ebay in a 3.5" to 4.5" range. Also, just to throw this out there, I saw a photo of a DJ where someone installed a monitor in their overhead console. I don't have a console, but would buy one if possible. Any thoughts on this?
Thanks in advance, Dave.
Yes, my monitor is 4.3" (exactly the same size than the useless one above it), with the bezel it takes a few mm more on each side. You can try if it fits with a paper (or better cardboard) template.
From a quick search on aliexpress a 3.5" monitor has more or less the same size as a 4.3" one, I couldn't find any 3.3"
