How to remove the brushed aluminum trim for wrapping
Fireball111
Yes it just pry it off with plastic tool , there was a video around
showing Coastal Tech radio upgrade during which they took that
trim off.
Confirmed. They are just snap on and the video mentioned was what I used as a starting guideline how to pry the trim for wrapping.
As xdesign said, it is better to start from the sides closer to steering wheel and pry all the way down to vents. I started with the shortest part for practice as this was my first ever wrapping project, but it turned out pretty easy to do.
I used plastic prying tool, but I guess flat screw driver with a cloth around it carefully applied will do, but prying tools are so cheap now, and you can use them for manyrojects, so my choice was to buy the set (something around $15) from ebay.
Good luck and no doubts you will enjoy the result many times, because this trim is what you see every time you drive :)
Edited by Totemus
