2012 R/T AWD Rallye
lytefall
Not sure of your build date but this flash is out there.
NUMBER: 18-024-12 REV. A
GROUP: Vehicle Performance
DATE: November 03, 2012
SUBJECT:
Flash: MIL Illumination P0108 - Manifold Absolute Pressure Sensor Circuit High And
Transmission Shift Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
2012 - **2013** (JC) Journey
NOTE: This bulletin applies to vehicle equipped with a 3.6L or 2.4L engine (sales
code ERB or ED3) and a 6 speed automatic transmission (sales code DG2)
built before **October 23, 2012 (MDH 1023XX)**.
SYMPTOM/CONDITION:
The customer may experience any of the following:
· Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the
Technician may find that P0108 - Manifold Absolute Pressure Sensor Circuit High
has been set active or stored 3.6L engine.
NOTE: **MIL Illumination for P0108 - Manifold Absolute Pressure Sensor
Circuit High affects 2012 model year vehicles only.**
· 1 - 2 upshift clunk or bump 2.4L & 3.6L engines
· 3 - 4 harsh upshift at closed throttle after a WOT stab in 1st or 2nd gear. 2.4L & 3.6L
engines
· 4 - 5 upshift clunk or bump 2.4L & 3.6L engines
· 5 - 6 upshift clunk or bump 3.6L engine
· 6 - 5 downshift clunk or bump 3.6L engine
· 6 - 4 downshift clunk or bump 3.6L engine
· RPM Fluctuating or Jerking feeling while operating in cruise control. Condition is
more noticeable when the vehicle is going up and down grades.2.4L & 3.6L
engines
· 1 - 2 harsh upshift going down a grade 2.4L engine
· 3 - 2 downshift clunk or bump 2.4L engine
· 4 - 3 downshift clunk or bump 2.4L engine
· **Improves the consistency of how shifts are controlled during upshifts “torque
management”**
Updating the software will correct the condition listed above.
Just went into the dealership for my 8000 km oil change (as per owner's manual) and I complained about thr shifting and driveabality issues. They found and applied the above service bulletin and the vehicle runs like a champ!! Thanks to DodgeCares for supplying me with the necessary information to lead them to this bulletin.
  • Official Dodge Support
Glad it worked.
  • 2 months later...
