graytoni Posted January 15 Report Share Posted January 15 My dodge journey 2013 has a temperature gauge for transmission that is 140 degrees if it's right in the middle of the gauge. For almost a whole time i've had it's always run at 140 or under. Recently, I noticed it running up to 170 degrees, which is about three quarters of the way up the the electronic temperature gauge. I am not short on fluid, and I believe it was topped off Just recently when I had an oil change. So unless i'm running bad fluid and I don't kown it I don't understand why it suddenly jumping up thirty degrees. Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 15 Report Share Posted January 15 1 hour ago, graytoni said: My dodge journey 2013 has a temperature gauge for transmission that is 140 degrees if it's right in the middle of the gauge. For almost a whole time i've had it's always run at 140 or under. Recently, I noticed it running up to 170 degrees, which is about three quarters of the way up the the electronic temperature gauge. I am not short on fluid, and I believe it was topped off Just recently when I had an oil change. So unless i'm running bad fluid and I don't kown it I don't understand why it suddenly jumping up thirty degrees. so what eng do you have?, 4 or 6 spd trans?..did you have the transmission fluid changed or just topped off? temp outside also driving conditions and manner of driving will affect temp change Quote Link to comment Share on other sites More sharing options...
