Anglhrt Posted April 13, 2025 Report Share Posted April 13, 2025 I have a 2019 Journey Crossroad I bought in October 24. I've just now had the opportunity to turn on the A/C and found that when I put it on A/C I get cold from the front left vent but heat from all the others. What's causing this, anyone know??? Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 13, 2025 Report Share Posted April 13, 2025 Y1234 refrigerant system...Quite possible a small leak in the A/C system or slight possibility that pass blend door actuator is not working. It works the same for A/C and normal HEAT/ cool. IF those function well for pass heat change, then I'd say A/C system leak, and probably a small leajk at that due to drivers side seeming good, indicating low refrigerant. Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 13, 2025 Report Share Posted April 13, 2025 IF you are getting cold air from one vent but not the others I would say it is a blend door problem Quote Link to comment Share on other sites More sharing options...
Anglhrt Posted April 14, 2025 Author Report Share Posted April 14, 2025 Yes, I read that might be the issue... thank you ☺️ Quote Link to comment Share on other sites More sharing options...
