Light bulb issues. Any ideas?
Hi everyone,
I've got some weird issues going on with my Journey and I was wondering if anyone has any ideas how to troubleshoot or what to replace to correct the issues.
Issue #1: BOTH rear license plate lights do not work (tried new bulbs in both and they still don't work) but my rear tail lights work fine.
Issue #2: The passenger side, front turn signal light (square orange) only works when signalling. Both should be turned on when the lights are on and not signaling.The drivers side works fine.
Any ideas would be appreciated.
Cheers
Hmm, we had an issue with the license plate lights melting to the sockets and the wiring harness was replaced under warranty, that was 2 years ago, also a good first thing to do is check fuses and try installing a new turn signal bulb (didn't say you tried that) maybe sone of the filaments burnt out. I looked on chiltonlibrary.com and couldn't find any wiring schems. for the journey. Hope you find out whats going on, last thing you could do is take it int the dealer.
