Brake Control Install
SaskGuy
So, today I ran all of the wires to install my brake control in my 2011 Journey. When it came to the brake signal wire, I had a problem. The normal way of hooking this wire up would be to find the wire at the brake pedal that supplies 12 volts when the brake is pushed. My test light was not showing any such wire, so I pulled out the multi-meter. The only wire that changes when I push on the pedal is the middle one (of 3) but it only changes from 1v with no pedal to 2v when pedal is pushed. This will not operate a brake control.......
Does anyone know a different place to get signal from? Anyone know a Dodge mechanic who will share this info?
Thanks
Perry
  • 1 year later...
i to would like to know whitch wire, here what i found,
Vehicle Wiring Details for your
2011- Dodge Journey Wiring Diagram Printer Friendly
Version
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2011- Dodge Journey . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections. More information on using a multimeter and testing wires please see our Technical Support Area.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ BCM, LT.GRAY 4-PIN PLUG(C2), PIN 3, SEE NOTE #2 STARTER LT.BLUE/TAN (+) for STARTER KILL ONLY!! @ BCM, BLACK 24-PIN PLUG(C1), PIN 19, SEE NOTE #2 STARTER 2 PURPLE/LT.BLUE (?) @ KEYLESS IGNITION NODE (START/STOP Button) BLACK 6-PIN PLUG, PIN 4 IGNITION 1 PINK/WHITE (+) @ BCM, BLACK 48-PIN PLUG(C5), PIN 27, SEE NOTE #2 IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 N/A ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) EHITE/BROWN (-) THRU a 1130 Ohm resistor, use a Relay to ISOLATE Switch @ BCM, BLUE 24-PIN PLUG(C7), PIN 20, SEE NOTE #2 PARKING LIGHTS ( + ) SEE NOTE #3 @ BCM, SEE NOTE #2 POWER LOCK PURLE/LT. GREEN (-) THRU a 330 Ohm Resistor will LOCK @ BCM, BLACK 48-PIN PLUG(C6), PIN 23 (without One-Touch up Windows) SEE NOTE #2 POWER UNLOCK using same wire, a (-) THRU a 100 Ohm Resistor will UNLOCK DIAGRAM DOOR TRIGGER PURPLE (-) @ BCM, BLACK 48-PIN PLUG(C6), PIN 25, SEE NOTE #2 DOMELIGHT SUPERVISION YELLOW/PURPLE (+) @ BCM, BLUE 24-PIN PLUG(C7), PIN 14 SEE NOTE #2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN DK.GREEN/WHITE (+) @ BCM, BLACK 24-PIN PLUG(C1), PIN 23, SEE NOTE #2 TACH BROWN/YELLOW, BROWN/DK.BLUE, BROWN/LT.BLUE, BROWN/TAN, BROWN/ORANGE or BROWN/PURPLE (AC) @ Any FUEL-INJECTOR, 2-PIN PLUG, PIN 2 WAIT TO START LIGHT N/A BRAKE DK.GREEN/WHITE (+) @ BCM, WHITE 24-PIN PLUG(C4), PIN 18, SEE NOTE #2 FACTORY ALARM DISARM N/A ANTI-THEFT NO INFORMATION AT THIS TIME!! See NOTE #1 EXTRA INFORMATION
NOTE #1: There is NO INFORMATION on the ANTI-THEFT SYSTEM or an INTERFACE BYPASS MODULE for this vehicle AT THIS TIME!! NOTE #2: The BCM is located Behind the GLOVE BOX. NOTE #3: The LEFT FRONT Parkinglight wire is a WHITE/BROWN (+) @ BCM, BLACK 24-PIN PLUG(C1) PIN 4, the RIGHT FRONT Parking light wire is a WHITE/ORANGE (+) @ BCM, WHITE 24-PIN PLUG(C4) PIN 3, the LEFT REAR Parking light wire is a WHITE/GRAY (+) @ BCM, BLACK 48-PIN PLUG(C6) PIN 32 and the RIGHT REAR Parking light wire is a WHITE/ORANGE (+) @ BCM, BLACK 48-PIN PLUG(C5) PIN 4, when connecting
use a relay for
