Hi everyone!
2010 Dodge Journey AWD with a 3.5L SOHC V6 engine and 165,000 km (103,000 miles).
The engine makes a rhythmic metallic knocking noise that increases in frequency with RPM. It also runs unevenly and noticeably shakes at idle.
Several mechanics have looked at the car and given different opinions, but no definitive diagnosis has been made.
I'm aware of the common issues with rocker arms, rocker shafts, locating pins and hydraulic lash adjusters on these engines.
I'd appreciate it if someone could watch the videos of the engine running and share their opinion.
  • Does this sound like a rocker arm problem?
  • Could it be a rod bearing or a piston wrist pin?
  • Has anyone experienced this exact type of noise on their 3.5L engine?
  • What turned out to be the actual cause in your case?
Unfortunately, I currently have no way to read the fault codes or check compression and oil pressure.
Any advice from mechanics and owners with firsthand experience with this engine would be greatly appreciated.
Thank you!
