trevcda Posted April 3 Report Share Posted April 3 I did a modest search and did not find anything that seemed match up with my issue. My phone is connected to Uconnect, but when I take a phone call, it seems to randomly loose part of the connection without dropping the call. Sometimes it comes back and sometimes if I end the call on the phone it holds on to the phone connection like it thinks it has a call and doesn't go back to radio until whatever times out the earlier issue happens again and then it goes back to my previously schedule program. This phone works fine in my other vehicles, so I don't think the trouble is there. My brain says update firmware, but I don't even know if that's thing with this system. I may try the pinned suggestion about pulling a fuse at the top of this forum. Where should I be looking? TIA! Here are the particulars: 2009 Dodge Journey Sofware Application 9.112 Gracenotes 534 Hardware Serial number T00BE021851504 System 6826 006 3.3 Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 3 Report Share Posted April 3 HFM/ bluetooth/phone module is pretty OLD for an '09 model, how new is your phone? There are postings of your similar situation here{keep looking}. And how long has this issue been happening with your DJ? I doubt it is an issue with "Uconnect" but the HFM/bluetooth/phone module going bad, and there are numerous postings of this. I have 2 '13 models and a '17 with the HFM/bluetooth/phone capability, I have only had to replace the module on one of the '13's I have to get it to work ( I got the car with it not working), and 3 different newer phones all work well with all three on mine. Quote Link to comment Share on other sites More sharing options...
trevcda Posted April 4 Author Report Share Posted April 4 The phone is Pixel 6. I think it started last year before I put it away for the winter. I didn't realize that system was modular, but I use Uconnect as an all emcompassing term for the infotainment system. I'll search some more. I'd appreciate in any links may have or even a successful search phrase. Where is that module located? Maybe the fuse pull isn't such a bad idea afterall. Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted April 4 Report Share Posted April 4 35 minutes ago, trevcda said: The phone is Pixel 6. I think it started last year before I put it away for the winter. I didn't realize that system was modular, but I use Uconnect as an all emcompassing term for the infotainment system. I'll search some more. I'd appreciate in any links may have or even a successful search phrase. Where is that module located? Maybe the fuse pull isn't such a bad idea afterall. I've NOT worked with the 1st gen DJ's to know for SURE. But if like the '11+ models, it should be over the brake pedal bracket for module location. As far as where the fuse is, I can't say as there seems to be confusion of location for an internal fuse panel or not having one for the 1st gen. DJ's. PERHAPS a Google search could help you out about which fuse and where. Good Luck , and keep us informed....seems to be a resurging trend of 1st gen owners coming around for needed info. most of us have the newer year models. Quote Link to comment Share on other sites More sharing options...
