cansub Posted May 26, 2024 Report Share Posted May 26, 2024 2012 SRX R/T AWD. I have the rear of the drive shaft to the differential carrier removed fine. I've removed the center bearing (bracket) and the 6 x 8mm bolts on the front of the shaft. However, the front of the shaft will not budge. I've tried banging, air chisel etc. Is there some trick to removing it? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted May 27, 2024 Report Share Posted May 27, 2024 Maybe the domed end is stopping it. Try pivoting it down in the middle where hanger bearing is. May need to spin rear wheels, have tranny in neutral so you can manipulate shaft position a bit. Quote Link to comment Share on other sites More sharing options...
dieselJosh Posted May 14, 2025 Report Share Posted May 14, 2025 Does anyone know the installation specs? Torques for fasteners, center bearing preload procedure, etc? Or which of the online repair guides is going to actually have this information? Thanks. Quote Link to comment Share on other sites More sharing options...
