Suspension Squeak?
I am now getting a squeak on the front passenger side....squeaks when the suspension is in motion....hope I can get a fix.
Anyone else had this squeak?
Either your strut is defective or, more than likely, you have dirt in your bushings. During the winter they put salt and sand mixes on the roads to help with traction when it freezes or snows. Try spraying the components in the wheel well (behind the tire) with a water hose or power washer to see if it gets rid of the noise. Good luck!
  • 4 weeks later...
I have had the squeak come and go on each side, especially when going over a small hump like a speed bump . I took it to the dealer and they said that my struts were leaky and they replaced them under warranty (24,00mi) and the squeaks are now gone.
My vehicle is the same model as yours.
I have had the annoying squeak come and go on each side, especially when going over a small hump like a speed bump . I took it to the dealer and they said that my struts were leaky and they replaced them under warranty (24,00mi) and the squeaks are now gone!
