Spinnefx Posted Tuesday at 09:27 PM Report Share Posted Tuesday at 09:27 PM (edited) I’m working on a 2020 Journey Crossroad and stumped. All power windows (at all doors) and sunroof stopped working. Electrical diagram shows they only relationship between the two is a wires from both going to what the diagrams calls a “run/accessory relay 1” located in the interior PDC (fusebox, right lower end of dash). This shows a 5 pin standard relay. Problem Test Drive Dodges is, I don’t see this relay in the fusebox. As a matter fact, the drawing says it has 3 relays I do see one which a 4 pin. I looked on the immediate backside of the fusebox but don’t see any relays. I’m attaching the drawing in case I’m missing something, but if anyone has any thoughts on this please advise. And, for the record, I’ve tested and swapped all of the fuses and or other relays in the under hood distribution center as well. Additionally, just for kicks, I tested one of the windows manually (used a power probe at the switch) and it worked fine just in case the motors in each strangely went bad at the same time - but I almost with.certainty that this wasn’t the case. Finally, no other issues or codes. I welcome any thoughts. Thx. Find Engine Parts Edited Tuesday at 09:29 PM by Spinnefx Added detail Quote Link to comment Share on other sites More sharing options...
