Robert Miller Posted 1 hour ago Report Share Posted 1 hour ago I drive a 2013 Dodge Journey in Little Rock and I'm setting up home charging for a plug-in conversion project I'm slowly working through in my garage. The electrical side is where I keep second-guessing myself. My garage subpanel has a 60A feed, and I want to add a 50A Level 2 J1772 charger, but I'm not sure the existing panel can carry the load alongside the air compressor and welder I use on weekends. I've seen a 50A J1772 unit listed with adjustable current settings, which sounds useful for limiting draw, but I'm unclear whether dialing it down actually reduces the breaker requirement or just changes the output. I also don't know if the Journeys wiring bay area has enough room for the charging inlet without cutting into the bumper support. Has anyone here run a 50A Level 2 charger on a 60A subpanel with other equipment, and did you need a load calculation or an electrician before pulling the trigger? Quote Link to comment Share on other sites More sharing options...
