never had an issue with remote start....this winter after having battery woes, remote start would shut off after activated. I put a new battery in and it does the same thing.
after using the remote start by pressing the button two times on the FOB the DJ will start, then after 5 seconds it shuts off. this is most discouraging when it's cold outside.
the FOB will no longer work to start. you have to manually walk out in the cold and insert it.
can't figure out why. I do see a coincidence -this occurs when the12v  battery may not be fully charged.
