2014 Dodge Journey Daytime Running Lights
DRL are mandatory in EU too, but only on new models.
I thought so also. It is entirely possible that I can't see all the equipment or sales codes from a domestic (US) database system. However, that is all I have access to, at least for now. We'll see what Mr. Marchionne has up his sweater-sleeves for the future :)
DRLs are mandatory in the EU for models that have been type approved after 2011. Since the fiat freemont got its type approval well before that date (when it was sold as dodge journey), they could get away without installing DRLs, even if it's a supposedly new model (it isn't).
Now, I don't know it the DLRs as implemented in the journey/freemont (high beams at half power) would be street legal here, most probably they aren't (stupid EU rules) so that's maybe the reason the sale code isn't available. But, even if they don't comply with the regulations, they would be much safer than no light at all and more convenient than keeping the low beams on (since that also dims the dashboard illumination).
Hi Journeyman,The last 8 digits on the VIN is ET134293 approximate KMs is 250. Thanks in Advance for your assistance. you are boon to journey family.. :shift:
Chrysler activates the DRL's for the Canadian market. Are yours not working or is B.C. different?
Edited by rolly
I checked your VIN. The Sales Code LMK already exists in the Standard Equipment field in the Build Sheet. It is not available in the Options area for me to add it since it is already there. If they are not working, please check in with your dealership - there may be a diagnostic fault code active which could prevent them from working.
Here is your build sheet (it does not copy and paste well on this forum; everything runs together rather than carrying over in chart form from the Chrysler site - sorry)
Vehicle Option - All Standard Equipment Code Description Code Description Code Description APAS Monotone Paint BABS 160 Amp Alternator BCPS 525 Amp Maintenance Free Battery BGES Brake Assist BNBS Electronic Stability Control BRES Anti-Lock 4-Wheel-Disc Brakes CACS Low Back Bucket Seats CBDS Active Head Restraints CB9S 2nd Row In Floor Storage Bins CFJS Rear Reclining / Fold Flat Seat CGDS Front Height Adjust Shoulder Belts CGUS Child Seat Anchor System-LATCH Ready CGYS Drvr Inflatable Knee-Bolster Air Bag CG3S Advanced Multistage Front Air Bags** CJ1S Supplemental Frt Seat Side Air Bags CJ5S Supp. Side Curtain All Rows Air Bags CKCS Floor Carpet CKTS Cargo Tie Down Loops CLPS Door Sill Scuff Pads CTLS Base Door Trim Panel CVMS Full Length Flr Console Prem A/Rest CWPS Illuminated Cupholders GAMS Solar Control Glass GBBS Tinted Windshield Glass GFAS Rear Window Defroster GNAS Rear View Day/Night Mirror GNFS Driver Side Sun Visor w/Mirror GNYS Passenger Side Sun Visor GT6S Power Heated Mirrors, Fold-Away GXDS Remote Proximity Keyless Entry GXRS Keyless Entry GXXS Sentry Key Theft Deterrent System GX4S Keyless Go JATS Premium Instr Cluster w/Display JA2S Instrument Cluster w/Tach JA6S Premium Instrument Cluster JDJS 240 KPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJBS Dual Note Electric Horns JKFS Cowl Mounted Hood Release JKPS 12V Auxiliary Power Outlet JKWS 12V Center Console Power Outlet JMAS Air Filtering JPBS Power Locks JPDS Power Windows, Driver One-Touch LAXS Front Passenger Seat Belt Alert LAZS Vehicle Information Center LBCS Glove Box Lamp LBLS Driver Passenger Lower LED Lamps LCAS Front Courtesy/Map Lamps LCES Rear Courtesy/Reading Lamps LCSS Incandescent Stop/Tail Lamps LDFS Liftgate Flood Lamp LHDS Headlamp Off Time Delay LMES Halogen Quad Headlamps LMKS Daytime Running Headlamps, High Beam LPSS CHMSL Lamp LPTS Backup Lamps MDAS Frt License Plate Attachment Screws MFDS Bright Grille MGNS Dodge Badge MHAS Black Windshield Moldings MNKS Body Color Door Handles MPFS Journey Badge MPJS Black Sill MPLS Black-Out Tape MP2S Silver Mold In Color Fascia Applique NFPS 20.5 Gallon Fuel Tank NHKS Engine Block Heater NHMS Speed Control QAUS Granite Crystal Met. Clear Coat RCGS 6 Speakers RDBS Removable Short Mast Antenna RDZS Steering Wheel Mounted Audio Ctrls RHAS Uconnect 4.3 AM/FM/CD/MP3 SBBS Firm Feel Power Steering SCAS Steering Wheel SDCS Normal Duty Suspension SUDS Tilt/Telescope Steering Column TBKS Compact Spare Tire TVKS P225/65R17 BSW A/S Touring Tires WFJS 17X6.5 Aluminum Wheels XHLS 12V DC Front Rear Power Outlets XJGS Non Locking Fuel Filler Cap X81S Instrument Panel Parts Module X82S Door Parts Module X83S Front End Parts Module X84S Front Suspension Parts Module X85S Rear Suspension Parts Module X88S Tire Wheel Parts Module YACS Build To Canada Mkt. Specifications 1ABS Canada Dealer Retail 125S Zone 25-Canada-Alberta 5IUS JC/5702 Vehicle Family 5I3S Dodge 5I8S Left Hand Drive (LHD) 5LBS 2014 Vehicle Specifications 5ZBS Price Class H 5ZUS Front Wheel Drive (FWD) 594S Vehicle Order Tracking 6CSS Canada Specifications Label 679S British Columbia Province Code 8HFS Canada Country Code Optional Equipment Code Description Code Description Code Description *E5 Prem Cloth Low-Back Bucket Seats -X9 Black AGV Flexible Seating Group BNMP Traction Control BNSP Electronic Roll Mitigation BNTP Trailer Sway Damping CAUP 3rd Row 50/50 Fold/Reclining Seat CDHP Driver Height Adjuster Seat CDKP Easy Entry System Seat CG4P 2nd Row 40/60 Tilt Slide Seat CS8P Delete Cargo Compartment Cover CX8P CORA Tire Press Monitoring Sensor DBAC All Automatic Transmissions DFF 4-Speed Automatic VLP Transmission DHDP AutoStick ® Automatic Transmission EAGC All Gas Engine ED3 2.4L I4 DOHC 16V Dual VVT Engine HAGP Air Conditioning w/3 Zone Temp Cntrl HBBP Rear Air Conditioning w/Heater LE4P Black Exterior Mirrors MCXP Dodge Body Color Fascias NAS 50 State Emissions NHJP Exterior Mirrors w/Heating Element PAU Granite Crystal Met. Clear Coat RFKP 4.3 Touch Screen Display RSUP Audio Jack Input for Mobile Devices RSXP Remote USB Port TZLP Kumho Brand Tires XBNP Tip Start XGMP Tire Pressure Monitoring Display XLNP English/USA Language YGNA 4 Additional Gallons of Gas ZCFP Spring - Left Front ZCUP Spring - Left Rear ZREP Spring - Right Front ZRUP Spring - Right Rear Z1BP GVW/Payload Rating 0E7A FAM: JC TRACKING: 30513S13 MY:2014 2DFA Customer Preferred Package 2DF 22F Customer Preferred Package 22F 3XAA Federal Green Levy 4CPA Federal A/C Excise Tax 4EX Sales Tracking 4HC Special Scheduling Condition III 876P Canada Region Group 894P NAFTA Region
Edited by Journeyman425
Thanks alot :) .No its not working on my journey..This weekend i will take it to dealership and ask them to fix.
Question for Journeyman425? Will you check my vin for daytime running lights capability, please? ET106705. 2014 Journey Limited. I was so disappointed since the option does appear on my uconnect screen.
Apologies to those drivers out there this foggy morning...I really thought my lights were on!
Edited by Beancounter
Beancounter - I think you gave me an incorrect VIN. ET106705 comes up in the Chrysler system as unsold. There was a warranty claim on if for new car preparation by Hill-Kelly Dodge in Pensacola Florida. I looked on their website and it is still in their new car inventory. You may be off a digit on the VIN, perhaps?
I re-checked tonight and yes, your dealer has reported the car sold and in your name. However, I do not find a sales code for your VIN in the database. I'm seeing this pattern for 2014 vehicles. There must be a change in the configuration for this year that I am missing. Please see this thread:
http://www.dodgejourneyforum.com/topic/5509-drl-for-my-2014-journey/#entry35424
Thank you, Journeyman425. I'll follow both threads in the hope that a resolution is found. I drove around for two days thinking my drls were on. I like having them on so that other drivers can see me coming. Apparently, drivers around here can't see silver vehicles...lol.
Take care.
Checked your VIN, and just like every other 2014 I've checked, I cannot find a sales code for DRL. I don't understand it. When you go to your dealer on Tuesday, ask them to do a vehicle scan and see if there is another way to enable them. I would expect them to do this as a courtesy to you since you've only had the car for two weeks, yes? Please keep me posted. I've been wanting to hook up one of our 2014's in stock and see for myself, but there simply has not been any time for me to do that.
We used to do that years ago on occasion - it's called changing the Country Code. For instance, I could enable DRL in my 2000 300M by changing the Country Code to Canada. I was not sure if that was even an option to do anymore on the newer ones, to be honest. One of these nights after work - if I can ever find the time - I want to pluck a 2014 Journey off the lot and plug it in to our Wi-Tech system and find out how to enable the DRL for myself. If and when I ever get to do this, I'll post my findings.
Journeyman, I'm new to the forum and was gonna post about getting my DRL's activated. It just happens to be the very first thread I started to read. Apparently it's common that they don't work. I have the on/off option in the soft keys menu as well. I tried to send you a PM but the spam blocker won't let me PM anyone until I have 5 posts....LOL....so, can ya help me out? The last 8 of the VIN are:CT197297
Thanks,
Rick
I added the sales code for you. Now, the car has to return to the dealership for a vehicle restoration, or reconfiguration. It's like restarting your home PC after a major update - the settings don't take effect until after your computer is restarted. Same here - when your dealership performs a restoration, the new sales code "LMK" is picked up by the car and after that you'll be able to toggle the DRL on and off using your touch screen.
I added the sales code for you. Now, the car has to return to the dealership for a vehicle restoration, or reconfiguration. It's like restarting your home PC after a major update - the settings don't take effect until after yo!ur computer is restarted. Same here - when your dealership performs a restoration, the new sales code "LMK" is picked up by the car and after that you'll be able to toggle the DRL on and off using your touch screen.
Great, thanks
I had to do that with my 2008 Jeep Hemi Commander... Changed the system to Canadian and then the unit would allow the enabling of the DRLs and once they were enabled via the StarScan tool, the system was changed back to the US country code changing the rest of the display off from the metric measurements and the DRLs stayed on. Was a PIA, but, it was all we could come up with after months of experimentation. I posted the process on one of the Jeep XK forums and it worked for a lot of the others there.
