Lower front control arm bushings
I have a question about the bushing on the front control arm . I am talking about the one at the rear of the control arm where it mounts to to the kmember.
What at is the normal amount of play that is allowed with this bushing . Mine moves up and quite a bit . Not enough to hit metal but with a pry bar I can move it up and down a bit
Just a little noise mainly over rocky roads . A soft thump and also if I back up over a uneven spot  .  I also get a bit of noise while going slow over rough roads but I traced it down to  brake pads rattling becuse if I put slight pressure on the brakes it stops.
